I am having an issue with our vs540 feeding a job to cut back straight. I printed a job to be laminated then cut on 10' of reflective, removed it after printing, laminated it and now when I try and run in back through the vs 540 by the time it gets to the crop marks at the end it has moved over 1" to one side- thus it does not find the back 2 crop marks.
I have tried everything I can think of- rolling the media up and feeding it from the back and aligning the crop marks- I even have marked the media clamps (which you cannot use on a vs540) used that mark to get my front crop marks dead on even. I have even lined up the rear marks and reversed the media with the vs540 and still ends up askew. I am using 4 pinch rollers and have made sure the media is completely over the drivers under pinch rollers to hopefully make it grip even. All my edges were sheet cut so they should be straight and I have made sure the front crop marks are lined up right on- I could be a degree or 2 off (as I have no way of telling that). This is lettering that if at all possible needs to be in one solid run, not 2 5' pieces overlapped.
Any help or suggestions here????????????????
Larry
Larry
