I have done two installs now on the HHR. I get frustrated and really need some advice. The area where the rear fender flare meets the body is of course an issue.
Two different ideas I have tried.
1. Start from the top and work to the bottom. When getting to the area I speak of I have bridged it (not all the distance) then heated and pressed into the area that I have put primer on.
2. Start from the front and work horizontally to the back and feed it into the area as I go back, but that caused wrinkles after the fender that I had to work out.
YES, I want to take an install class to further my learning curve but living in bum f**k nowhere in MN I have to wait until Spring when the classes start.
ANY help or pictures to illustrate i would be grateful.
