phototec
Anyone know what vinyl material this could be:
High heat sticky back vinyl stencil material FOR FIREARMS, PAINTBALL GEAR, AIRSOFT GEAR, ETC...
This is a very high quality high heat sticky back vinyl stencil. It is a peel and stick vinyl that is perfect to use with Cerakote, Gunkote, and Duracoat and safe to use with oven cure applications (not to exceed cerakotes recommended cure temperatures). These vinyl stencils will not bleed like polyethylene stencils and you won't waste hours upon hours cutting a stencil that will ultimately be inferior.
This is by far the best method for applying a pattern to your firearm or whatever else you would like to use it on. cut out stencils take a very long time to do, smear the paint underneath, and don't allow you to get around the contours very well. Cutting your own takes hours and hours and cannot ever achieve the precision of this stencil. Save yourself time and headache by using this beautiful, already cut stencil.
