So I think I might have to admit defeat on getting my Mutoh RJ6000 up and running for my business.
The printer was converted to eco-solvent ink before I purchased it. The guy I bought it from had all the old parts that had been switched out... he replaced everything. The printer, mechanically, prints fine. I had to do a lot of work on the lines and cleaning everything, because it had been sitting with ink in it unused for a few weeks before I bought it. I did a lot of trouble-shooting, replaced dampers, o-rings, cleaned print heads, re-aligned everything. and got it back to a solid machine (great test prints on plain paper).
After a lot of time and energy spent on getting it back up and running... to my dismay, after finally getting to the point of doing test prints on banner material... I'm discovering that you simply can not print with ecosolvent ink on banner material and vinyl with the RJ6000. I have no idea how the guy was using the printer before I bought it... he had lots of eco-solvent used cartridges that were in a box that came with the printer so I know he was making it work somehow.... but It has no heater units and the ink does not adhere to the vinyl at all when I try to print. All the inks bleed into each other and its just a mess.
I even tried heating up the vinyl before I printed, and still get the same results.
So it seems I've got a "mechanically" perfect functioning printer, that will never be able to print jobs.
I understood the chemistry behind eco-solvent ink before I got into this project, but I thought it would simply take a lot longer to dry without the heaters, and that I'd still be able to get away with printing.
I have learned a great deal this past month though... and reluctantly... I've got an order in for a new value jet.
