How do i get Roland Cut Reg Dots into Optiscout??
tedbragg
I just discovered Optiscout 7 (we're way behind) can use Roland cutting reg dots. Only problem is, I can't figure out how to get a cutfile out of Versaworks or via postscript into Opti that it can understand. This would be a HUGE GODSEND for me!!! I've had to go around the world a few times when working with our xr640 and the SharpCut. Soooo many manually created layouts, so much time blown.
Anyone know how these two can work together?
cornholio
You need to add the optiscout marks before you import the design in Versaworks. Should be done in the design ptogram. Then in Optiscout, you can search for the marks.(or put it into an appropriate layer from the beginning)
  • Agree
Reactions: 1 user
