How do I hold a contour cut overnight?
Phil Swanson
I was told that if I want to print out to the edge of a contour cut that it has to dry overnight and then be laminated.This will prevent the edges from curling.
How can I hold the contour cut overnight?
LittleSnakey
in the contour cut setting tab, select send as separate jobs
on the first tab select hold in list not send now.
send to product manager
both jobs will be in the manager now and you can send the print then send the cut.
eahicks
The separate contour cut part will always 'hold in list' no matter if you send the print job immediately or send the print to 'hold', as long as they are sent as Separate Jobs, which should be your default setting to begin with.
thewood
I also like to hold my cut files until I manually delete them in case there is an error during the reading of the crop marks. Otherwise, once you send the cut job, it is gone. This has saved me on several occasions.
Setup>Default Job Properties>Workflow>After Output>Hold
