How do I print backlits on HP45500
dasigndr
anyone have any idea how to print a backlit on a clear poycarbonate on the HP45500 UV flatbed? There is a setting for backlit roll material (which works absolutely awesome, beautiful vibrant prints), howeveer ther is no setting for printing a backlit on a rigid sheet. I tried creating my own but it does not give me the option of telling it that it is a BACKLIT I am printing, therefore telling the printer to apply more inks.
Any help please???
dasigndr
return to origin
OK., but who is to say the registration will be exact.
I will try.
Thanks, dennis
dasigndr
sorry
OK, sorry. I was not aware. I only wanted to make sure it was seen by as many people as possible to get the most help possible.
Thanks, dennis
Mspec
I would run the rigid sheet while using the backlit profile you already like, run it at 1200x600 resolution, and in HQ mode in order to get the highest saturation. I assume since you are running on clear material that you are doing a reverse print, and plan to put a white backer of some sort < cast white vinyl, latex paint applied by a roller, sheet of white backlit film ) behind the backlit sign to give it the most pop.
Good luck.
dasigndr
Good luck.
I got it going last night Finally!!! I did just what you stated and it turned out super vibrant!!
