How is 3M 680cr compared to 180 for installation?
zapblam
Planning to test wrapping city buses with reflective prints.
How does 680cr compare to 180 for both installation and removal.
It is the removal that I am concerned about.....shall never ever forget the pains of removing standard reflective off police cars.
JBusch260
680cr is a removable reflective, so it isn't a terrible process.. if it has been on primer, it can be a slight burden to remove. Easiest is to just soak it with adhesive remover and use a soft plastic edge to scrape, making sure to keep it wet to avoid scratching of any kind. The rest, with a little bit of heat, comes off very nicely.
addition: Installation is pretty similar... but keep in mind that it is exceptionally thicker, so mind any bevels. On flat surfaces, it's a cakewalk.
