How much heat can Avery/3M vinyl withstand?
WhatsYourSign?
A client of ours would like to put some cut vinyl on the side of their smoker but I'm not sure how much heat will be too much for the vinyl.
Does anybody have any experience with this? Thoughts?
Thanks in advance!
Is it an insulated smoker? Many competition smokers are, and are not hot at all on the outside. Most smokers are also going to cook at 250 or less also. Reflective vinyl has a higher heat tolerance, which is why it is commonly used on brake calipers and in higher heat applications.
