Need Help How to add Split Lines(Cut Lines) to Contour Cuts on Flexi using Graphtec
trafficbarriersolutions
TRAFFIC & BARRIER SOLUTIONS, LLC
Hi, I am needing to add cut lines to my contour cuts on Flexi so that I can weed my vinyl out easier without having to over weed some important materials printed. I can add split lines when I cut regular vinyl that is not a contour cut. However, I don't know how Flexi allows split lines added to contour cuts. Is there a way to add contour cut split lines using Flexi to make it easier to weed out?
FrankW
You can set split lines manually by doing a right-click where you want them, or using the automatic split line feature in the third tab.
