How to adjust Toucan LT capping station?
signstop1
My capping station isn't lined up correctly on the heads and I'm getting a couple nozzles blocked. I've done a ton of maintenance myself including replacing the maintenance assembly, grit roller, etc. but I can't quite figure out how to adjust the placement of the capping station. Any suggestions or insight?
Thanks!
randya
Two basic ways.
1. Wet the caps, cap the heads, uncap the heads, move the heads all the way to the left and see where the caps are setting on the heads. Adjust the station accordingly.
2. Remove the carriage cover, get a good flashlight and align the stations to the heads.
(if I am not mistaken, you may have to remove the wiper tray to see the head/cap alignment) so do this with the power off and be careful with all the sensors.
