How to calculate speed of oscillating blade cutting foamboard?
tedbragg
Is there a formula for calculating how fast to move a oscillating blade when cutting different materials? I do a lot of .25" foamboard. Most of the time I set it to 60 ipm. Sometimes 75ipm. Cut looks the same, but I don't like to press my luck.
A preset I found in Optiscout had the blade going at 150 (!!!) Kida gunshy with cutting foamboard, as it'll pill and gum up in the worst places. What's the consensus?
Superior_Adam
every material, different knife blades etc will be different settings. Go as fast as you can without damage to the material. If you can successfully run at 150 do it.
MGB_LE
What does the cutter manufacturer say? Colex provides a cutting speed/feed chart by material. It gives us at least a guideline.
