How to remove sublimation ink from mugs?
Angelina wayn
There are following methods to remove sublimation ink from mugs:
1: Play with vinegar and draw the unwanted design:
Vinegar may be used in removing sublimation ink from mugs, and it is a tried and tested procedure.
2: The dishwasher Method:
If you want to remove a design from your coffee mug, run it in the dishwasher many times on the top rack at a high temperature. Some particles from the old design may persist after a few cycles, but the most should be gone. When it comes to removing sublimation inks off mugs, this process involves less effort but more time.
