How to remove UV Ink from a sign without ruining the print
Boudica
What do you use when you get UV ink off the belt?
you should be able to clean it off with ISO alcohol. If that doesn't work you can try straight alcohol (fuel). If there is ink under the file name... I don't think you can remove it without removing the ink behind it.
