dont think so you can shrink metal but not plasticNew help, put too much heat on pan faces while removing vinyl lettering. Faces now have big knots and waves. Is there a way to fix this without spending $1400.00 on new faces?
You're either gonna hafta eat it, or make a customer very angry. How could you over heat it to the point of melting it ?? Didn't you see it happening while doing it ?? Are these in your shop or up on the cabinet ??
I was thinking to do the same, maybe with a sheet of mdf or particle board, straight and heavy. Put one under it, heat it all and sandwich it with a second piece.I would not sand either. Would try to put something flat underneath and head back up and take another flat piece and press down to try and get the bulge or wrinkle out. Worth a try anyway. That is an expensive mistake.
