SugarShadow.EXE
Hi! I work mainly on Illustrator, but now do contour cut stickers on flexi and an HP 64 Cutter. Is there a way to take a pre-existing vector shape in flexi and give it contour cut properties? I ask because the Contour Cut filter on flexi gives way too many anchor points, and Flexi's Reduce Points feature is sub-par compared to Illustrator's Simplify feature. So far i can only do contour cut on preexisting shapes by giving it the Contour Cut filter with a 0.00 offset. I want the shapes i make in illustrator to be imported onto Flexi and just turned into Contour Cut lines, but as they are, NOT generated by Flexi.
Thanks in advance!
Thanks in advance!
