I had a failing carriage belt on my HP 365 so yesterday I replaced it with a new belt assembly according to the service manual. Unfortunately, the service manual tells you to unplug all the flex cables and remove the PCA board, which in hindsight I don't think was necessary and I did find it a little challenging to plug all those flex cables back into the board. After completing the job I turned the printer on and now I'm getting the message "Printhead appears to be missing, not detected, or incorrectly installed", then it tells you to "do a printhead replacement one at a time and close the door after each one". This really doesn't make sense as I've removed and reinserted all the printheads at least 20 times, one by one...all together...but when you do it one by one do you do it with only one printhead in the machine or do you leave all the printheads in and just reseat one at a time? The machine doesn't do the same thing each time, sometimes the carriage moves back and then comes back for another printhead replacement and sometimes it simply tells you to open the door again. I have also restarted the machine at least 20 times too but no matter what I do however, I can not get the machine to get out of this loop and recognize the printheads. Does anyone have any idea what might help me out in this situation? Thank you!
