Hey Sign Making community, I have an issue I hope one of you might know the answer to. We have an HP Latex 115 that is not curing properly. HP has replaced most of the boards, harddrive, pressure sensor (pip), air pressure sensor and all the heating elements. The machine is also clean. Mainly, perfect greys (with clean hue option in flexisign so only black is printing) 10%-30% come off the most then any other ink combo. What I think is going on, is the optimizor is too thick for small ink dots and it does not cure because of that. I can print grey with zero optimizor and it does not rub off. Once I add even a small percentage of optimizor (which is needed for almost all images), the greys rub off. Really this goes for any light colors, just the most with perfect light greys. Orginally I thought it was a firmware issue. Im not entirely sure what the actual issue is, those are just my theories and HP doesnt know either. Any Ideas would be great. Thanks
Material used is: HP Prime Matt GP, HP Gloss Air Optimum (all with HP Material Profiles)
Side Note: There is two theories that exist in HP regarding Optimizor. Number one, it holds the ink dot suspended in optimizer, so it doesnt spread out. The other belief is, it is a bonding agent as well as suspending the ink. I always thought it was the first theory.
