HP Latex 360 Line Sensor Replacement
jc_0125
Creative Director
Need to replace the line sensor on my 360. Was getting a 55:10 error and the machine won't boot up now. I was able to locate the sensor on the carriage, but does anyone know how to remove the silver part on the carriage [highlighted in red]. I need to get behind that to remove & replace the wire. I don't want to just pull up and potentially break something.
balstestrat
Problem Solver
There's clips on the left and right top sides. Just push them in and pull the shield upwards. It can be a little stubborn, use a small force.
Putting it back... same thing. It's a bit stubborn.
Then you should also calibrate the sensor in the service menu. I like to use SAV.
ToTo
Professional Support
But you don’t need to remove the cover, because you can disconnect cable at the line sensor. Unclip by pushing the connector frame upward.
