mjohnsonsa
For some time now I have had a problem with my HP Latex 54 cutter tracking going off the line sporadically on the Y axis while cutting. I have been unable to find any correlation except that it seems to happen more on larger cuts (over 40" long or so). I will have a single sheet with many nested cuts and some will cut perfectly on the contour line and then some will track way off; all on the same cut job (which seems to rule out calibrations). Sometimes it cuts the the graphic on the sheet that is way off first and then corrects for the remaining graphics and sometimes it is the last cut that messes up, there is no pattern where "once it starts going off it stays off" on the cut job. I even have it sometimes cut way off on part of a cut and then mid-cut right on the line on the other part of the cut on the same graphic. I have attached a photo showing a cut out of a 48" tall elf and you can see the left side of the cut it was off by over 1/2" and then on the right side it cut perfectly on the line. The problem has occurred on all kinds of vinyl, using Flexi 12 and 19, various firmware versions, all the calibrations, cleaning OPOS sensor and rollers, etc. have tried everything I can think of over the last several months to no avail...
I have wasted a lot of vinyl and ink and as of yet HP support has not had a solution to explain the problem.
I am at my wits end and am hoping someone else here has had the same problem and can share how they resolved it with me!
Elf example of bad cut:
Matt
Matt
