FactorDesign
I'll start by saying the vast majority of experience in wide format printing has been working in small shops with Roland printers, and printing with either Versaworks or FlexiSign, so there's a good chance I'm either overlooking something obvious or was just never trained in the proper methods of color matching with a latex printer and more advanced RIP software (Onyx 18)
Setup:
HP Latex 560
All heads original with about 2L through them
New cleaning cartridge installed
Media: 3M IJ180c V3
Profile: 8 pass 600dpi
Media has been 'calibrated' on the machine.
All heads appear good in the dropout tests.
Most of the time the requested pantone colors in PDF files made in Illustrator match, or are close enough to not worry about. Sometimes they are a little off and I can use swatch books to make small adjustments.
Recently I've been dealing with multiple colors that are either light beige (matching a paint color) or medium greyish (Pantone 430C), and simply unable to come close.
When printing 430C, the result is something with a purplish color, but nowhere near close to 430C.
As a test, I printed out the full pantone chart from the Onyx samples folder, and it appears quite a few of the colors are very far away from what the pantone book shows and I'm worried that the printer is becoming less accurate with color over time or that I've managed to tweak something in the software either in Onyx or on the printer that would cause the printer to no longer print as expected.
I've attached a printout of 430c vs the pantone color chart as an example.
Does anyone have any suggestions as to where to start to figure out if it's either the printer, Onyx, the alignment of the planets, or some other problem I'm not thinking of that might be throwing off the colors or how to get them back to matching?
Setup:
HP Latex 560
Media: 3M IJ180c V3
