jallison25
Hi All,
having a weird issue and wanted to reach out before contacting HP.
I am in the process of running banner roll to roll for a customer of various sizes. I ran 38, 54, and 63 in banner with no issues. But when I moved up to 80", the printer seems to have stopped applying the input tension. as it's printing, every time the media advances, the input would spin freely. That causes the printer to believe that its aout of material when in fact it is not. I've checked to make sure all of the latches for the spindle are down and locked, made sure the spindle gear and the motor gear are locked in and engaged, I ran the substrate movement diag and all motors report ok. My input tension is set at 125 the max is 150. all of my vacuum settings are at 750 the max is 1300. Not sure what else to check. I've fully shutdown and restarted a dozen times.
Any suggestions?
Any suggestions?
