Need Help HP SCITEX FB550 TCP IP SETTINGS
bastropsigns
I got a new computer, and can't get my printer to talk to my computer.
Running Onxy rip.
My computer is not online, it is hardwired via ethernet directly to the HP Scitex FB550.
What are the settings for the network adapter?
and what are the settings for the printer? It should be under Manual Settings.
HulkSmash
If you're direclty connected to the printer, im pretty sure you need a crossover cable, not regular Ethernet cable configuration.
FrankW
You need to set at the new PC a fixed IP-Adress in the same subnet than the printer: the first three number groups of the IP-adress have to be the same as at the Printer, the fourth have to be different.
Windows defaults to DHCP, but if connected directly, no DHCP-Server is available to assign a valid IP-adress. It have to be done manually.
