Banners Signs Etc.
The machine -Versa-Art 640
The problem -No Magenta
I give up, I've tried everything I know to do at least twice the magenta nozzle test print is a scattered maybe 25%
We swapped a magenta ink cartridge mid print (like usual when it beeps at us) and it went for a foot or two and turned the red banner yellow..(magenta quit)
Since then we could find no reason as to why it stopped...we have taken it apart and run cleaning cycles replaced (and overnighted) a set of dampers and it still will print a few inches before losing the magenta. We had replaced the capheads in january
Tried to suck ink from above the dampers it came through smooth and easy
Tried to -gently- suck ink from the Y-joint below the magenta caphead very little bubbly ink came out...tried sucking another color for comparison and more ink came out the there was less negative pressure in the syringe
tried switching capheads (thinking it was a bad seal) with a working color same result
it prints magenta for a half inch then turns into some light watery yellow color
tried switching cyan dampers with magenta ones it worked initially but the second time i tried it didn't
I figured well it is either a bad cartridge lot (unlikely) or a bad printhead (worse unlikely)
Got a new cartridge same problem...
The most mysterious thing is the light yellow that the printhead does output when I send a pure magenta rectangle unless somewhere there is a touch of yellow in the translation
Long story short
It is as though the magenta printhead just cant get ink into it or it is broken
The print test shows all colors firing except a scattered magenta
A big thanks to Bobby Fosson of Cibersupply for the informal tech support he offered me, but alas I am stuck.
Long story short
