Precision
What setting do you use on your graphtec for this type of cut contour/cut through decal?
Graphtec says use tool#3 at a speed of 20 and force 10+ over the kiss cut setting. Also when setting the cut pattern depth, the settings give you 7 options, but then the graphtec video say, instead use this "User" setting an these custom numbers 1.50" and .035". I don't know what I am not getting here. Appreciate any help.
Using the settings Graphtec is reccomending, I cannot seem to get tool #3 to give this a good enough cut, not to have to wrestle the pieces away from the vinyl. Something a little deeper and more consistent would be good.
Printed vinyl by itself is not a problem. Appreciate any comments. Thx.
