imagepro
imagepro
Need help with vj1604, black nozzles are not working. When strong cleaning
I see nothing coming down the waste tube. Should I try to take the maintenance station apart and clean? Any help would be appreciated.
Border
First, trying sucking through the drain tubes with a syringe. Check damper for leaky o-rings too.
h82loose
Clean the cap with cleaning fluid. This will help create a good seal. If the cap is not sealing good, you can push up from the bottom with your finger. It is tough to reach and be careful not to pull of hoses.
imagepro
Where are, and how do you get to the drain tubes and damper? How does one know
whether the cap is sealing good?
