Question In Roland VersaWorks
Once a file is sent to the VW rip, can the file be taken back out and put back into say..... Illy ??
I made a file yesterday, thought I had saved it (but didn't because of an interruption), sent it to cut only, cut the job, only to find out this morning, I didn't save the file. I had put about 45 minutes into building and creating this file, so it would be nice if I could get the file back out and just insert it back into this customer's folder.
:thankyou: Gino
Probably not but check the VW folder for a temp or working folder. Sometimes rips will save a copy in a folder while it processes and you might get lucky that it is still in there.
Vohaul
:thankyou: Gino
versa needs a file to rip from.....so it had to be saved before it ripped and cut.....is it not in versa anymore?..or did you print straight to versa.....?
I always make pdfs and load them into the rip....have a big transfer directory where all the pdfs are stored (and saved job info from versa)..so if ever i need to reprint, i can just load up the saved job file....
