Industrial Strength Hole Punch
Andrew Hodgson
I am in the events industry and we print hundreds of booth id signs. We currently use a hole punch to cutout holes on the top left and top right corner of the sign. Right now, I can only hole punch about 10 sheets of 100lb card stock.
Is there an industrial strength hole punch that can go through a stack of 100-300 sheets at once? I would only need a 1 hole punch machine.
MNT_Printhead
Working among the Corporate Lizard People
You should look into getting a drill press that the litho/small format print shops have, you might even be able to sub it out if you have volume.
