Even if media is covered remember that this is winter time. Cold== dry conditions, we heat the media when printing, when you take it off it cools, if you cover it immediately you can get minute condensation on the surface, if you don't you can get dust.
Since this only happens in black I would be more inclined to think that it is ink level related, as in, your black build is too dense for the given media.
Even if you print on the same media consistently, lots vary by manufacturer and ink limiting can change in a dramatic fashion.
Check your black build, unless you are using 100% black and no other colors, I would bet it's this. If you're building your black, try 25/25/25/100 as a max and adjust downward from there.
Check your heat, you should be in the 32-35C range, remember your heat should go from hot to hotter to hottest ( pre/print/dry)
