Hey guys, First off, Sorry for only coming when I have issues and not really adding to the value of the forum. I'll start bumming around more often.
My Mutoh 1204 With OEM Inks New maintenance station and new dampers is have an issue with my black ink.
My ink ran out on black and the printer thought I still have 5 % left. I swapped ink and changed the dampers at the same time (Had new dampers and I figured I would need to do a little charge anyways.)
3 Little charges and 5 or 6 strong charges I am still having issues. I can fill the lines full of ink but if it sits for about 15 seconds it will start to drain back to the cartridge. I swapped back to a different damper and have the same issue. I checked on the orings and it looks like it in good condition. (Maybe they look good when they aren't?)
It seems to only be pulling back on one of the 2 black ink lines. Would a cracked manifold do this?
Thanks again for saving my butt guys.
