I have a problem I have not seen before. The first inch on the right side goes from light ink to the amount of ink that should be put down. If I print two 1 inch lines vertical the first has the problem, but the second prints fine.
I have done a head test and it looks good. I have not changed ink. I did change dampers and "O" rings. I uninstalled Flexi 8 and reinstalled it (this seems to fix most of the print problem I have) The printer in almost 4 years old, I am using Flexi 8.
Has anyone seen this problem?
