is there a stronger spring for a dx5 capping top
SightLine
No idea on the actual pressure. Never heard of or seen a "stronger" spring but if you think your spring is worn just stretch it out some. I've done that before and it works fine. Just keep in mind that if you make the spring too strong you will cause much faster wear on other things like the tracks the capping top rides in and the capping top itself.
