Stu Friesen
I print wraps with a Roland VS-540i. and use 3M IJ180CVJ3 and 3M 8518 Gloss laminate. I recently printed and applied a mostly black wrap to one of our black company vehicles in order to have the image fade to black and stop at door seams in order to not have to wrap the entire truck. The printed black was not very close to the painted black. I have found through viewing other topics here that I believe I have been using the best possible methods of design (Corel X6) and export to versaworks to achieve the purest black. Beyond this, I believe the only way that I can see to achieve this is to print with the Versaworks print setting at "High Quality". With in a test print, this looks very close to the paint color. The question I have is: What drawbacks are there in using the High Quality ink settings? I believe that the ink will negatively affect the adhesive, possibly making it more aggressive. Is this an accurate assumption? Will it still be just as repositionable as normal ink amounts? Will the vinyl be more pliable and possibly too soft? Will the ink thin easier when stretched? Is extra time needed for outgassing?
I have always printed wraps with standard print quality settings and up until now have had no print issues. Any help or advice would be greatly appreciated.
