Having issues with a JFX EX model. Been fighting this for 2 weeks to no avail. The problem I'm having is that after about 2-3 prints, the printer starts dropping a significant amount of nozzles on both heads and the print becomes very banded. If I run about 5-6 hard cleanings the nozzles all come back and it will print fine for about one run then the same thing occurs. Things that I've done so far:
- Changed all primary filters
- Emptied subtanks and removed them to check for clogs and made sure the floats weren't stuck
- Verified that all ink pumps and solenoids are functioning via #test function
- Changed the filter on the air pump
- Lastly I changed both color heads
Nothing has worked thus far. Is this one of the PCB's failing? I'm at a loss here, any input would be greatly appreciated! Thanks
