copage2002
Hi
Each Morning White Does not come through when printing. I look at the head and the white Ink has pooled underneath the head, I do a head fill from maintenance menu and it is then happy although the next day the problem is back.
I have done an Air purge.
Pressures are all reading correctly.
If I put the carriage to head maintenance and kill the power I do not see any ink leaking so either it is gradual or happens during its cleaning cycles
I recently changed a couple of boards on the Printer. One was one of the front INK boards.
On the EX the print boards are (INK System II Boards) they are different to the normal JFX200 and the EX has 2 rather than one (one is just a secondary board that had a few connections to it from the main Print board).
I struggled to get a INK System II Board but could get a normal JFX one and as only a couple connections to it and labelled the same I used that. All seemed fine so I am not sure if my problem is related to that or just a coincidence although it did happen around the same time.
When did the change of the Boards the printer went to a factory reset, could any parameters be causing the problem?, I am happy to go into the parameter menu but not sure what I am looking at really.
Also, If the capping station is not quite close enough could that cause the ink to seep? I doubt it but running out of options.
Any help would be very much appreciated.
Thank You
Thank You
