backenwright
Hi Guys
I have been running this JV3 for some years now and tackled many issues with dampers/pumps and everything surrounding them but this one has me stumped.
If you look at the attached image of my test draw I have just successfully pulled the Magenta and Black back from being completely dried out as I had an air leak in the dampers and didnt realise until it was too late so hav spent a day to get them back (this isnt our main machine anymore but is used on occassion as backup)
But the problem is that the cyan although fine before I changed the dampers on the Black and Magenta now has this nasty bit missing in the middle and after many dishway/wash/soaks you name it I cant seem to get the middle strip back up and running, it looks pretty much like a head crash which is impossible due to it not having actually printed or been used in between discovering the ink starvation problem on the other colours, and also bearing in mind at this point the cyan was printing just fine.
In every head crash I have seen so far you can tell its that due to the bend in the lines which this shows no sign of either so im a bit lost as to what to try next other than swapping out the white head (which isnt used and will take a good while to clean up) or swap for the light cyan and magenta as I really dont want to be looking at spending 1k to sort out a printer that isnt even our main machine if I can help it!
Any ideas appreciated
Leon
Leon
