JV3 New head, only one side works, need help
olesign
We have been having some trouble with our Mimaki JV3 SPII
The one side of the head was not printing anything. I did the clean on the head, took the over off the base and the dampers have ink and are full of ink in the lines. Took the head out and purged the ink thru it without any luck.
So we replaced the head. Same problem is occurring.
On a different problem. When we replaced the head we also removed the black dampers to get them out of the way and now only one line has ink and is not printing correctly, Similar to the red, but there is no ink in the line or the damper. Could this be caused by air lock? If so how do I go about removing the air from the lines?
Thanks in advance!
Case
you need a technician or you need a syringe to prime the damper with ink manually...... but i imagine if you didn't know to do this that you don't know how to do all the head alignments either...
case
olesign
Actually I tried to prime the damper.. But when I filled it up and removed the syringe, the ink just sucked right back out of the damper. and I'm back to square one.
But this doesn't explain my first question as to why only half the head works, Both dampers are full, would that still need to be re-primed so to speed.
Case
could not be sealing on the cap very well............did you wet and clean around the cap real well? start with the small ones first........no leaks in lines, no damper leaks, o-rings all in place? hopefully didn't crack a stem on the printhead.....
then you could go on to larger things........slider board, slider cable, mainboard, etc.........
could be many factors........start with the small non electronic things first........
case
anthony smith
We did the same thing a few weeks ago turned out the damper had
a very small hole in it and would not allow to prime
Jack Knight1979
this happened to me with a new head. You need to prime the head by putting syringe on the head manifold and squirting in cleaning fluid until it comes out the bottom of the head.
You will then have a solid hydraulic flow from the cart to the head nozzles. This will do the trick. Also replace the cap if it's over six months old.
anthony smith
We also replaced the complete caping station and it help a great deal on the quailty
of printing did not realize the importance of the seal around the heads
the pumps can also be weak all are easy but as you know expense fixes
olesign
Okay. I primed the head, no luck. So next I pulled the ink into the damper with a syringe but as soon as I'm done pulling it thu pulling ink in the damper the it all just flows back out. What am I doing wrong here?
Thanks for all the help so far!
SE SignSupply
Check the cartridge level for that line, make sure you have plenty of ink.
If the level is fine then check for leaks around the manifold (where the damper plugs into the head), damper itself (these don't fail often), the o-rings where the ink line screws into the damper. Somewhere you will find a air leak.
Ryan
