Hello,
What is the best and easiest way to setup a through cut job without having the job fall out off the sheet before it's completed? We are getting a job with several stickers and one cut will be a contour cut and the second will be a trim around the job. I have found that if the pressure is too deep, then the sticker will fall out after it's trimmed causing the whole sheet to jam when the rollers hit the space. Basically, I want to be able to pop them off the sheet after the cutting is done.
If anyone has a helpful tips, I'd appreciate it. Thanks.
