PrintQueen
We are experiencing a new issue on our Kala laminator and wondering if anyone is familiar with fixes. I’ve attached a video showing the issue for reference.
https://www.dropbox.com/s/pw4avxs0pxk7gyy/VID_20200813_093912.mp4?dl=0
Essentially what we’re experiencing is our long laminated prints begin to create a V shape on the printed material we are feeding in. After a long enough time, the V create a buckle and an air gap. Here are the things we’ve already tried:
I did some research and saw a term called “Boat Waking” that is relatively common. It would seem like the outer parts of the rollers are pulling at different pressure/rate than the center section.
Any ideas on how to get this fixed? I know there's another tension knob on the roll of laminate -- is this the culprit? Should these adjustments be made as I'm running material through and starting to experience the wave forming?
- New setup of laminator roll and material
- Let material sit overnight
- Cut the printed feed material in a bowed in and out shape
- Feed both by hand and from the feed roller
- Use with and without the takup roll
- Adjust tension on the laminator supply roller
