Need Help Lamination for UV prints
Roniz 1
Looking for a good matte lamination for UV prints,
I am getting alot of silvering using 3M matte
need something that will adhere better to the texture of UV prints.
ProColorGraphics
I am LOVING the Hexis VCR750 laminates!! They are designed for sticking to UV prints with a more aggressive adhesive. Give Liz at Platinum Sign Supply a call!
UV prints almost always require heat assist for pressure sensitive laminates in order for them to lay down into the texture. If you don't have heat assist, that's the problem not the laminate. You can also use a spray laminate but hat gets messy.
