For Sale LED Light Channels For Marble/Tile Inside Corner Installation
ledbe
Check the LED Light Channels, which can be recessed into the Tile or Marble, you can use them for inside corner installation. the Light Channel with a " V " shape design, comes with a clip-in diffuser for smooth light output, you can use them in tiled areas like kitchens, bathrooms or swimming pool areas, etc. the standard length is 1M and max length can do 6M, cuttable and you can cut to any length for your projects. the aluminum base can be used as a heat sinker for better heat dissipation and allows a longer lifespan.
Link: https://www.ledbe.com/Internal-Recessed-Tile-led-linear-light-profile
Features:
  • Material: 6063-T5 Aluminum Alloy
  • Surface Treatment: Silver Anodized
  • Model: ALP088
  • Size: 56.3*22.4mm
  • Colors: Silver, White, Black
  • Inner Width: 10.5mm
  • Max LED Strips Width: 10mm
  • Standard Length: 1Meter
  • Other Lengths Available: 0.5Meter, 1.5Meter, 2Meter, 2.5Meter, 3Meter
  • Custom Length Available: YES
  • Diffuser: PC Diffused Cover
  • End Caps With Wire Hole Included
  • Installation: Inside Corner Recessed
  • Applications: Recessed Into 10mm Tile Or Marble
  • 5 Years Warranty
