Saturn
Your Ad Here!
Looking for thoughts or philosophies on limiting the shrinkage of laminated & die-cut stickers that remain on the backing paper for weeks/months before being used. There should be some worst case sample photos at the bottom of the post.
I use GF-203 and Oracal 210/215 to great effect for the most part, but have noticed that some stickers definitely end up shrinking MUCH more than others. Obviously they're all going to shrink a noticable amount, being (calendared) vinyl, but I'm just curious if there's some things that I'm doing in the handling that can either help prevent it, or even help "pre-shrink" things.... Things like how it's stored between stages, rolled vs flat? Length of off-gassing, or length of letting it sit after lamination but before die-cutting.
Does temperature play a big enough factor that I can use it my advantage? Say, heating or cooling a finished roll before it goes to the cutter?
Probably not going to change the media for this issue, but any thoughts are appreciated! -Thanks!
