JASmith
HP 9000s 64" Large Format Printer, Air Purifier and Dryer $ 6,000
Create long-lasting outdoor signage with the fastest printer in its class. This 64 inch-wide HP Designjet is an excellent tool to boost production and profitability: increase your print volume, improve your services, and reduce your costs.
This printer is in great working condition.
Only used OEM HP 790 and Seiko inks the printer. Has been under a full warranty until last April so it has been well maintained and serviced.
Also included is an HP air purifier/filter and dryer
Summa Plotter S160 T Series 64" Includes: OPS and Wireless Option $8,500
S Class 2 T Series Specifications
Models S2 160-T 64-inch (163 cm)
Cut Type True Tangential with Drag-Knife Cutting Mode Capability
Cut Widths S2 160-T 62.2-inch (158 cm), Extended Mode: width of the material
Cut Speed All S2 models cut at speeds up to 56 inches (1414 mm) per second diagonal
Axial Speed Up to 4 G
Maximum Acceleration Up to 5.5 G diagonal
Repeatability Within ± 0.004 in. (0.1 mm) on plots up to 40 ft. (12 m) long
Tracking 164 ft. (50 m) long
Cut Force 0-600 grams of downforce, in 5 gram steps
Display Language English; French; German; Dutch; Italian; Spanish; Polish; Czech; Latvian; Portuguese
Connectivity USB; Ethernet
Power Requirements AC 100V to 240V ±10% 48-62Hz, 85 VA maximum
S2 160-T 88.6 (W) x 26.8 (D) x 43.7 (H) in. 225 (W) x 68 (D) x 111 (H) cm
Shipping Weight S2 160-T 251 lbs (114 kg)
Operating Temperature 59˚ to 95˚F (15˚ to 35˚C)
Standard Accessories WinPlot or MacSign Cut Software, CutterControl Parameter Software, CD w/ Manuals and Drivers, Quick Start Guide, Power Cable, USB Cable, Media Guide Flanges (set of 2), 1 Spare Fuse, Blade Holder, Standard Nose Piece, 2 Standard 36° Tangential Blades, Thick Material Nose Piece, 1 Thick 60° Blade, Tangential Drag Holder, 1 Standard 36° Drag Blade, Pouncing Pin and Holder, T Pen holder, 1 Ball point pen, Pouncing and Pen Nose Piece, 2 Cut-off Razor Blades, Blade insertion tool, Stand and Basket.
Optional Accessories Motorized Take-Up Roller for Summa S2 140 and S2 160
Media Rack for Summa S Class S2 140 and S2 160
Seal Image 62" Plus Base Laminator $9,000
Seal Image 62" plus laminator with the following features;
• Touch pad control with pre-programmed temperature, speed & substrate settings
• Automatic front & rear take-up shafts for release liner removal
• Swing-up in feed table makes material loading fast & easy
• 65" Heated Silicone rollers for effortless cleaning
• Simple film tension adjustment
• LED Setting indicators • Optional roll-to-roll operation
• Built-in cooling fans for smooth film surface during heat sealing
• Pull rollers that ensure consistent film tension for flat, even finish
• 6'/Minute maximum speed (1.8m/min)
• Swing out supply shafts for easy loading
• Foot switch for hands free operation Max Lam Width: 62"
• Anti-static pull roller Max Speed: 6' per minute • Ergonomic touch pad control panel
Added feature is the roll to roll option package with motorized take up
This laminator is in great working condition. There are NO CUTS on the rollers. Rollers stored in open position when not in use
Also available for sale for an added charge:
Everything you need to start up your new business, including the website design and domain name
cutting table 12ft
Cubicles-Desks 6
computers- 1 design computer with software, 3 additional computers, some have dual monitors
All in-stock vinyl material
cutting table 12ft
Cubicles-Desks 6
