I always wear cotton gloves when loading material.
After I load my SP540V, and before I lower the pinch rollers I do the following steps.
1) Grab the tail of the vinyl in the middle using right hand. You only need about 18" over the platen to do this.
2) Bend down and place my left hand on the loaded roll to keep it from turning.
3) Move tail of vinyl back and forth to find the "center". You'll know when it's there because the vinyl will be relaxed and lay flat.
4) Hold tail in place and use left hand to drop pinch rollers.
Notes:
Use all pinch rollers all the time.
I've found that running the other two pinch rolls as close as possible to the outside rollers works best for feed and contour cutting. YMMV
Never use the cut edge to align. Media drifts when printing, and using the sheet cut function only gives a straight edge based on the skewed media.
Notes:
Notes:
