Seal is EXPENSIVE. Service BLOWS! Customer giveadam? NOI PARTS NO, Seal NO!
my 62 Pro went to recycle thanks to the warehouse taking 4 MONTHS to ship out Parts.
Royal Sov. Customer Care I dont know but I heard the dude who headed up customer No Care
sought employment elsewhere. I have the RBH with top heat assist.
It is fast, Very Fast. Full roll in less than 10 min.
The Top Heat Assist Sails past 135 deg. So I monitor it with a laser gun,,,,,,(dont buy the General Laser Temp)
Roller Adjustment is a Major Pain in the Arse Rollers are crowned and with each adjust on either side
it see saws and instantly throws to other side off. There is a trick to it, and requires 5 points of measure
with pull testors,,, did you catch that plural s. A pull testor from RS is $100 and is basically a cheapo luggage scale and a
.002 SS strap 1.5"w x 14" L
Buy the cheapo digital luggage scale $6.00 each from walmart ebay or amazon. You will need 3, yes Three.
GFP has Temp Adjust, good speed and probably 100x easier to adjust than the RBH.
Your Options will be a rear take up reel. If you do not get this at time of purchase you will regret.
GFP also has a Slitter Option. While it is Pricey, that is a killer option to have. I agonize not buying GFP
for that option
No Matter who's Laminator you buy The company you buy from Needs to install it at time of delivery
and be competent to make the adjustments. If you think or if sombody tells you a new one will not need.
well they probably just lied to you and will give not one carp about you.
These things weigh 800lbs and the crate takes a beating during shipping
With Royal Sov.
Bell & Howell services Royal Sov in my area. they also service HP Printers.
My RS New, needed alignment after delivery. Royal Sov was acting badly and I was at a critical cross road
on a huge job, I finally said FK it!, and called B&H Service.
call 2 hr was $380.
When I spoke with the Billing Clerk at B&H. She said, your laminator is under warranty and tore up the invoice,
and billed that chit right back to Royal Sov. WTFG Bell & Howell
Go Put Hands on a GFP and review the Aligning procedures and every several weeks, tweak it if needed.
Plotters require new blades and offset adjustments.
Your Printers are Maint Whores.
Your Laminator will require attention too.
Rear Take up is Mandantory. It will be quoted as a seperate Item with GFP but is Std with RS and Seal.
NEVER go anywhere near a laminator with a sharp blade NEVER!
