Click to Support Signs101 ...
Hey Peeps, getting a wiper sensor error every clean cycle. It is happening because the gears are skipping and jamming. Does anyone know how to sync them?
Usually means it's time to get a new maintenance station. What you can try first is to clean the station focusing on the track and moving parts for the wiper.
Then use the 'Head Maintenance' option in the menu cycle the head off the station a few times. Seemed to get the gears working again and gave me enough time to get a new one on order.
Disassemble the maintenance station and replace double tube inside the perilstatic pump. And check if all teeth on small gear.
Or replace maintenance station complete.
Should have mentioned, this is a brand new maintenance station and has been in the machine for less than a day. The gears have stopped grinding and now ink is leaking from the pump so looks like it was faulty in a major way to start with.
Sounds like a faulty station. Taking it apart and putting it back together again is not easy and even then it's no guarantee it will work. I'd contact the person you bought it from. If it was us, we'll get you a new one.
