Maintenance Station replacement?
GAC05
Quit buggin' me
Mutoh VJ1304
My maintenance station is sounding like it is about to fail (second time in just under 2 years of use).
I have a maintenance contract but the sole tech is on vacation & I'd rather DIY than have it fail then have to wait until he comes back to get the printer back up.
I've got the new part and have read through the change out section in the service manual, looks simple enough.
Question I have is on resetting the pump life counter.
The guide is not very clear on this - at least to me.
It looks like I need to:
1. Boot up the printer in maintenance mode 2
2. Get to the "Counter Initialization Menu"
3. Find the "Init. 10 Pump" listing
4. Hit Enter?
This will reset just the pump value and not all the others?
I shouldn't need any of the maintenance apps or passwords from Mutoh to get to this menu should I?
There are 2 small brackets in the box with the assembly that do not show up in the step by step in the manual, I'm not sure what they are for but assume I will run into them when I get the covers off. They are black with white foam strips on one end and a single screw hole in the other, any clues?
Anything else I need to do or watch out for?
Thanks in advance
wayne k
guam usa
randya
You are correct on the reset.
No password is needed.
The two small brackets are for the 'ramps' on each side of the print head.
They are not needed.
