Map Drawing Line issue
heyskull
I have a file that was originally made for a pen plotter with multiple coloured lines.
I would like to bolden the lines so I can print it.
At the moment it is making them all hairlines and are hardy distinguishable.
This file has been created from an ordenance survey map and is highly detailed so I cannot select each colour to change the stroke width.
Is there a simpler way to do this?
SC
Boudica
Is the problem that the file is not CAD or vector in anyway - but a bitmap?
My first thought would be to use photoshop select by color, copy and past into it's own later, then add the stroke there. Rinse and repeat for each color. If I understand correctly.
Boudica
If using Illustrator, you can Select>Same>Stroke Color to select all of each color at a time.
That's what I was going to say - but after I looked up - ordinance survey map, I started thinking maybe he's working with a bitmap image.
aaand I just re-read the OP - and he said the file was created for a plotter..... so now I'm confused why he couldn't just open it in Illy or something and select same stroke colors.....
JBurton
Signtologist
I'm thinking it's hilariously complex...
I'm afraid you'll have to find a way to open it, at least in corel, there is a find feature, set it to given color, change width of outlines, done. Or select the whole set and give them all a bump.
One sloppy af way would be to export into a png at 1/5 scale, then scale that up. It will also pixelate everything else, and while the lines would be 'thicker', they'd be pixely too.
Boudica
It must be complex - in my head it seems like it would be really simple in illustrator, but I guess I'm missing something.
heyskull
Hi
I am using Signlab. Can it be done in Signlab. I also have corel suite and Adobe illustrator. I mainly use Signlab and the other ones are there if Signlab struggles to import a customers file.
SC
myront
Dammit, make it faster!!
Hi
SC
You haven't verified whether you're working with a raster file or vector.
Johnny Best
Open file in Illy. select some lines and then look at top left and see if they are strokes or fill. If they are strokes make them at leasE 2 or 4 thickness. If that works proceed with oTHers the same way.
If is is a bitmap and you can open it in Photoshop at a usable dpi, what I do is use the magic wand tool to select the thin lines. Then duplicate those as a new layer then duplicate that layer 5 or 6 times. Then you can shift each layer 1 or 2 or whatever pixels in each direction, and thus your lines will be thicker when you compress the layers.
