Click to Support Signs101 ...
Does anyone have a source for maroon solvent ink. Nazdar has some, but it's a transparent toner ink and you have to purchase it in 4 gallon lots. This is being used to screen print yard signs. Thank you.
7900 series, not fire red, I think it might be cardinal red, I'll check when at screen shop in the morning. Color actually prints a burgundy instead of red straight from can.
I tried that, not very happy with the results. I would rather have a source for more consistent color. I have a color card from Nazdar, none of the stock colors are really close to maroon. Rubine looks more light red. I'll give the Inktech a look. Thank you.
as far as mixing, it would be much easier to at least get a spot that is almost right. then add 1 part black, or 1 part yellow to the ..."20 parts whatever". that way your ratio is far more repeatable and the added parts are less sensitive causing less accuracy issues.
