Got laid off during the start of covid and took the Mimaki printer as the severance package. After a stressful move things have been ok, until the start of this week.
Out of nowhere the printer showed SYSTEM HALT (6) 811: fw / sio read. Tried to scroll through the messages to see if there were more codes, but it was frozen. After a hard power off it came back showing SYSTEM HALT (1) 11f : PCB SLIDER.
If I startup holding F3 it will get me to the firmware upload page where is gives me 3 other codes of 108(HD Thermis[_ ]) 519(Negative P. Sensor) 617(Subtanksens [123456]) which I assume is related to it not being able to cycle.
It believe it is out of warranty, and as such I feel I'm having a hell of a time getting support on a machine that's just over 2 years old.
I've had a very helpful tech assit with providing steps to check things. We first tried updating the firmware, but that did nothing. Same 11f error on restart.
I then was told to check the cables to the PCB Slider board and the ribbons to the printhead. I visually inspected as well as disconnected and reconnected all cables to the Slider PCB. Verified the power supply is putting out 48volts all the way to the Slider PCB. Same error on restart.
Ive checked all fuses I could see and they all appear good. I am seeing a red led showing on the Slider PCB so it appears to have power.
I am wondering what the chances are its the optical cable. I don't have (havent been shown) a way to test it. It looked as though the cable angle was sharp going into the main board and was run under some bigger cables instead of on top. Starting it up with the cable unplugged makes no difference in the code. Other than that I have no other ideas. Cable is over 500 dollars and has to ship. SLIDER PCB is over 1000 and has to also ship.
Without having access to the Diagnostic Manual I am left going on whatever info I am being given over days - all the while my previously perfect printheads are turning into garbage because I can't run a cleaning cycle. Just really sucks. I can't believe I may have to part out a machine that is barely over 2 years old.
Would deeply appreciate any help or advice. Especially any way I could at least save the heads while all this is trying to be sorted. Anyway to read the prior error codes would also be great as I can't access the menu at all to do so.
Sincerely,
JohnTom
Sincerely,
JohnTom
